largest inducer on twins
Old 09-12-2006, 10:42 PM
WUnderwood's Avatar
maybe a big brother with a SPS 66?
Old 09-12-2006, 11:19 PM
abc4yew's Avatar
II is testing a set of twins with a regular silver bullet over a big brother ....works great with a cp 3.4 and lots of fuel. Daily driver...probably doable if your skilled. ks
Old 09-12-2006, 11:29 PM
Luken's Avatar
Wouldn't that be a fun ride after it's lit With my little ole single at 20mph it lights the tires up no matter what the pavement surface is....
Old 09-13-2006, 08:00 AM
signature600's Avatar
Originally Posted by abc4yew
Chris, I looked at that turbo for awhile...I'll be very interested to see how it works out....It will spool faster than an s400 but unless you get a big compressor wheel on it I can't see how it can move more air....do you have a turbo map for it...I used to have one but I just looked and I couldn't find it. ks
It uses the same compressore wheels as the GT42/42R...Here is the link for the 75mm version!
That would be comparable to a S400/B2 wheel.
Hopefully I can get a bigger wheel put in there...if not, I'll just have to make do with faster spool only, Darn
Coolest part of the whole deal is is should be about the same price as a B2
Chris
Old 09-13-2006, 08:26 AM
abc4yew's Avatar
Chris, That looks like it should work just fine....you got the 757707-9 with the T-6 inlet right. Can't wait till you get that built up.
Luken, Brett's truck with the SB/BB twins did the 1/4 in 12's with two big let offs and coasting across the line....same as me he had a hard time keeping it on the track when he was spinning 3 corners in 4wd on the 2/3 and 3/4 shifts. Mine was bad enough with just 2 corners spinning. He wrecked the big brother at the Edge though because of a defective friction ring. ks
Old 09-13-2006, 09:12 AM
Luken's Avatar
ks, do they sell twin kits?
Old 09-13-2006, 09:50 AM
Actually, those are for the GT42's...mine is a 45. Different turbine wheel
I believe I can actually go clear down to a .91A/R housing...but I'm gonna go with the 1.15A/R T6 inlet. My charger is just a center section and wheels right now, no housings.
As soon as I get a tranny, the twins build begins...probably be after the first of the year, though
Chris
dodgediesel
ABDTR #5
10-18-2011 09:22 PM
dodgediesel
ABDTR #5
496
10-16-2011 04:33 PM
kantdrive55
33
01-17-2007 05:21 PM
satburn
20
10-02-2006 12:21 AM
More Power
09-17-2004 04:09 PM
Quick Reply: largest inducer on twins
