Knock or rattle after replacing lp
Old 02-05-2009 | 09:35 PM
turbopilot51's Avatar
I replaced my stock lift pump last month after nearly stranding me on the freeway. I replaced it with an Airdog FP-100 and it runs great. The only thing I am noticing now is a knock or rattle aroung 1000 to 1500 rpm. But never while accelerating or under load. Could the lift pump failure have caused damage to the CP3?
Old 02-05-2009 | 09:45 PM
Spooler's Avatar
I doubt it damaged the CP3. Wintertime is notorious for letting carbon build up on the injectors. Sounds like you are hearing a little bit of timing ratte. Another culprit would be the winter fuel. As soon as it gets warm enough hook up to a heavy load and go for a pull. Heating up the engine and burning the carbon off the injector tips does better than any fuel additive I have used, and it's cheap.
Zee
03-23-2010 10:54 PM
HappyGA
15
10-16-2006 09:21 AM
Hoss
30
10-03-2006 03:57 PM
sinwagon2500
16
01-10-2004 02:34 PM
