Kicking down at Highway speeds question
Is there a simple mod available to address the following...
I'm cruising at 60-70mph, I get on the gas a little heavy to pass someone and she kicks down a gear.
It drives me nuts, she has the torque to hold the gear but kicks down and my RPM's kick way up obviously.
IT'S ANNOYING!!!
IT'S ANNOYING!!!
Probably not, the shift enhancers advance the throttle pressure with less APPS on the 1-2, 2-3 shifts. Won't do a thing for OD control.
Either a lockup switch, lockup controller, or more power. The OD is ECU controlled based on speed and APPS position. You can't change it so you have to override it.
trailblazenyj
03-03-2005 12:48 PM
jnaker
36
12-10-2003 07:02 PM
Zeedaddy
96
08-25-2003 09:00 PM
