Keeping boost up?
Look here:
http://cgi.ebay.com/ebaymotors/DODGE...spagenameZWDVW
got the boost elbow in today and will install it at work in the morning. what p.s.i. should i set it to? i know 35 is the max but whould i set it back a little. also i should have the smarty in before setting it correct, or will it make a diff? also Tom lets see about the weekend of the 7th getting together for a few cold ones. i am off work Friday and saturday. maybe the track will be calling my name that weekend. i will call you later and talk about it.
It seems that the line going from the elbow to the wastegate has some kind of crimped hose clamps. one can they be taken off and reused or do i need to buy new ones, and two how do i take them off with out messing them up.
Thanks,
Eric
Thanks,
Eric
Or just cut one clamp off and use a SS hose clamp. It takes all of 10mins. More importantly, YES, I AM UP FOR COLD ONES! ANYTIME, ANYWHERE W/ ANYONE!!! Bring on the cold ones! Let's go have some cold ones and talk about where we're going to have some cold ones next! TB just bought a new fourwheeler, so we'll need to go riding also. You can rent one out at Rockdale(and we'll drink some cold ones!)
Installed the elbow and nothing over what i was hitting before. i only have about 1000 ft of road so i can't get going very well but i ran 2nd and 3rd up to redline and only hit 29 i hit 30 on the way to work with the stock slbow in it. now do i need to get into the higher gears to get max p.s.i. or should i hit it every gear? any ideas on why i can't hit 35 psi
Thanks,
Thanks,
it is adjustable. they said it comes open all the way. and i even opened it up more before my second run. i will have to wait till morning when i head home from work to really test it out. also inside the elbow it looks like it needs ported and polished. should it be smooth or should it have the little bumps?
yes turn the allen screw closed(clockwise) like stated^^^
the boost elbow usually gives about 7 #'s of adjustment either way.
Patriot_RAM
09-27-2004 08:11 PM
