Just ordered goodies!! Can't wait!!
Old 05-14-2007 | 03:26 PM
vzdude's Avatar
DTR's 'Go to Guy'
Not a very informative post, I know, but I just ordered the Quad Commander and XZT standard box combo with all the x-tras!( A pillar mount and fuel psi sender) Lary @ DTR was great! Just wanted to let people know there are some great deals to be had by buying thru DTR! CANNOT WAIT to get it installed!
Old 05-14-2007 | 05:16 PM
koogala's Avatar
You'll be happy with Quad. I didn't know anything about this stuff & I had no problem with the hook ups or anything. He has great customer support.
One piece of advice.....go e-a-s-y on the 3rd-od shift. THAT spot is where
xtra power will slip. Your truck is a year older than mine but the trannys are the same. If I want to rumble, I hit the tow/haul & do my last shift manually, letting off the juice when I make that shift, eeeeeaaaasing into od, much the same as a big rig shifts ranges. Those in the know say a performance t.c. &
valvebody will hold up to 500 hp, then its into a goerend or suncoast tranny.
tc & valvebody= $1,500 perf. tranny= 4-5k.....
Old 05-14-2007 | 05:56 PM
vzdude's Avatar
DTR's 'Go to Guy'
Thanks! I appreciate the info. Probably will use it for mostly towing, and I go easy on it then anyways. Will be fun to burn off a couple of tires too every now and again!
kerry.king
17
09-09-2012 01:28 AM
Justin26
11-11-2007 03:21 PM
mega duck
09-13-2007 02:22 AM
apprentice
05-01-2007 08:37 PM
getblown5.9
09-30-2005 11:26 AM
