Just installed my BHAF (pics)
Actually turned out to be extremely easy. Cut about 4 inches of a 4" pipe and ended up putting the IAD sensor where the battery holder hole is.
The only problem is that the filter itself is literally less than an inch from touching the alternator, not sure if thats going to cause a problem or not??
Never heard of Duralite. Looks good! Where did you get the filter and what did it run$? Does it have the wire mesh on the inside as well, like the Fleetguard Marine filters? Also, do you have a part #?
https://www.dieseltruckresource.com/...n&onlynewfaq=1
All the BHAFs are just relabelled Wix filters.....
VikingDiesel
08-01-2006 07:27 AM
