Just Installed Diablo Predator and Autometer gauges!!
The extreme on an 05 should definetly slip your clutch, if its not something is wrong.
You might have a previous download on it.
900' and 30psi on extreme at WOT...... something is wrong.
not exactly sure what you mean by surge? and it mostly smokes at low rpm and little bit at wot. However my truck was smoking a little bit even before the tuner, is this normal? Should i put to stock and get a reflash?
so i set it to "tow" before my drive home from work, and I noticed the boost was the same as extreme, spike at around 38. I also noticed a small decrease in power, but more smoke at wot. Does this sound like somethin is wrong. Should I look at the truck or the tuner?
read some codes under permanent codes:
control module programming error/not programmed
SKIM secret key not stored in PCM
anyone know what this means?
bsj04
08-10-2007 10:05 PM
bhuntt
07-12-2007 09:43 AM
38 Cigarette
06-25-2007 09:39 PM
lightening ram
06-09-2007 03:56 PM
