Just bought quadzilla xzt box. Any input?
Just bought the zxt box as i really don't need more power as my racing is done at the track. More mileage is what I am looking for. I have been a die hard Ford fan until this year. So far this truck is sweet. Oh yea I have the 6spd. Tried the auto on my trailer and did not like it. Not enough control over the trans for me. Any of you guys tried this box? I thought about the new bully dog box but didn't want to spend the money and do not need the power. Thanks, Jim
Use dielectric grease on the connections and you'll be good. I liked my quad when I ran it. I had the race box, but left it on 60 hp 90% of the time.
I hope you have an egt gauge, you shouldn't be adding any fuel without one. It's easy to see high egt's, particularly when towing.
Ordered my xzt box Monday before Thanksgiving, can't wait for it to get here. I hope to have some gauges under the tree this year also. Have heard good things about the tow box and I didn't want to be able to mess with it. Just plug it in and go.
i have the quad xzt box i am fairly happy with it .. it makes REALLY nice power and you'll be impressed with it's dyno numbers, make about 10 more horses than advertised .. but it still has that subtle miss and surge that alot of people including myself are complaining about .. but besides that i am very happy with mine .. plus you can hit about 45psi on the old boost gauge !!
good luck
G
good luck
G
I think quad is working on that issue. I believe he has an update for these problems, at least that is the way it sounded in his post. I sure hope thats the case anyway, don't want to have to send it back ounce I have it in and working.
I did not figure on gauges with this little of a box. I tow very light and I have no one else drive it. Do you think that I still will need the gauges as most people have told me no. I eventually will add it to be safe but wanted to put it off a little bit incase I do change to something nicer. Jim
from my personal experience I saw about a 100-200 degree drop in my egt's when I installed my xzt box. So that should give you some peace of mind but there is nothing better than knowing exactly what is going on.. I would suggest gauges but if you are strapped right now then I wouldn't worry too much.... Good luck!!
Just order a SRT-10 A-pillar, a perfect match and a Westach Boost/EGT gauge. $300 and you're done. Even cheaper if you go with an EGT only gauge.
Whatever you do, don't run w/o gauges. The 325/610's can get close to 1500 deg. stock.
I think everyones issues other than coobie's have now been solved. It was really a very small group to start with.
The latest stuff going out has all the new updates so you should not need to send it back.
Also once we have a week or two on the new fix from the people that had some issues we will put out some info on how people can get their modules updated if they want to.
Quad
Originally Posted by qzilla
You shouldn't have any issues.
Quad
Quad
Quad
Quad
Gary
1985cucv
06-12-2010 09:41 AM
YFZRidr91
03-06-2008 02:23 PM
bluebull
29
09-09-2007 08:02 AM
silkywoods
11-12-2006 02:11 AM
wdbates
38
08-10-2005 07:59 AM
