juiced!!!!
Set Level 1 "Low Boost" setting to 1. This is the most fuel economy setting. The way I understand it the Low Boost settings are the amount (percentage) of the maximum fuel that will be delivered for that Level until full boost is available.
Seems to work, level 3/low boost set to 1 is no smoke on WOT from stop, level 3/low boost set to 5 will produce black smoke(unburnt fuel) until turbo spools up and creates enough air to burn all the fuel.
Setting low boost to low values should keep from over fueling until enough air(boost) is available. This is just my opinion, I did not write the fuel maps.
Jagsfan811
08-28-2011 06:28 PM
omaharam
10-19-2006 11:33 AM
Dusty Ratcliff
09-23-2006 01:32 AM
RockcrawlingTJ
16
07-18-2006 10:26 AM
