juice tans slip monitor with adjusted pinion factor
Okay I am looking into the juice with the attidude and have read threads about the trans slip function not working if you have adjusted pinion factor. I have a lift so this issue affects me.
Now I called edge and they told me that the box was defaulted for 3.73 and if the pinion factor is changed the transmission slip would not read accurate.
Is this really an issue to care about? They act like it is not there problem but IMO it is. you can't expect every truck to have the same size tire and I am sure you can write code to fix this issue on thier end.
they way the tech told me it is not thier problem that thier box is not getting the correct info but the reason you reflash the pinion factor is so the computer is getting the correct info.
I was one of the first ones to identify this problem. They now state this in the documentation. For stock TC and Trans this is an issue, TC lockup monitoring and protection was a feature that I thought was very useful. Of course I found out otherwise.
It is the only real compaint I had with the Juice/Attitude. The power and driveability were the best of all the different performance products I tried. I think only the full Banks setup has any transmission protection for the Cummins trucks. I just was careful until I had the TC/Trans upgraded and then I did not worry about it.
They do seem to have an attitude that is counter productive to customer care.
wonder if the banks power pda has the same issue or if it can deal with the reflashed pinion factor.
that is funny. they told me that it was dodges issue. I am not sure the guy was the brightest though because he kept acting like I was chaning the gear ratio. I had to re interate three times I was talking about tire size.
the truspeed is now available on superlifts website
http://www.superlift.com/suspension/...03-RAM2500.asp
under options.
under options.
v8440
01-29-2006 02:48 PM
Geographic Void
13
09-08-2005 04:00 PM
