Juice/Attitude
Juice/Attitude
I recently had the Juice with Attitude installed on my truck. I checked the records after one week and it showed 8% slip. Is this something I should be worried about?. I have not been driving it hard. Scared to put in level 4. Mostly drive in level 1 for mileage. I have a new exhaust and AFE with Pro Guard 7 filter. IS this normal is other people seeing the same thing.
Re: Juice/Attitude
i also am running the juice attitude, i got a %7-%9 slip on the monitor before i did my trans, i recently went through the trans and did a precision triple lock converter and a shift kit and the trans slip gauge still shows the same %7-%9 slip. my shows slip from stock to level 5. i personaly don't think the slip gauge reads accuratly because you would feel it when it started slipping %9. i talked to edge and they said the slip i was getting was normal and i should only worry if it gets to around %25 slip (which conformed my beleif the the gauge is not accurate)
ryan
ryan
ryan
ryan
Also welcome to the DTR!
I have the NV5600 and I have gotten 7-9% slip as well. These numbers are when I go to level 4.
FWIW I have not tried level 5................................................. .yet lol.
How much does a cluch cost that will hold the juice or six gun? I have been wanting one of the 2 but I dont want to fry the cluch if it wont handle it. If that thing can read slipage I would be interested in what it says the tranie or, cluch in my case is slippin on the stock setting. Anyone know?
Ok I kinda had the same question my truck is an 05 6spd and I have the new juice and I tried level 5 in 2nd through 4th and the most slip I had was between 4%-6% so I turned it down to stock and did the same thing and got the same amount of slip? So I am guessing the gauge does not read accuratly. But if I pull it hard in level 4-5 in 5th and 6th I can feel it slip so I think if it was a concern you could feel it am I wrong?
Think about it,....
I hear folks talking about the slippage being an inaccurate measurement. Well I beta tested these for 4 or 5 months and the whole time I had a stock tranny and I was seeing 8% to 10% slippage and real world tear down of my tranny showed it toast. Tell me this if the gauges are soooooo inaccurate. Why since I did the ATS thing the most slippage I've seen, ...with the same Attitude, is 1% and mostly it is 0% on the Records field of the Attitude? Thinking that 8% or so is just a standard or just a gauge that is inaccurate may help you sleep but it doesn't change the facts. The 48RE is not capable to run anybody's 100hp box without toasting. Fact.
out-of-here
what did you do to your trans to get the slip to %0-%1 slip. i just did a precision triple lock converter and a shift kit and it did not affect the slip at all. i get the same slip reading from level stock to level 5. when i am on the freeway cruising at 65 all i have to do is lightly roll in to the throtle and i will get %7 slip in any level but i can't feel it slip.
ryan
ryan
What was done???/
out-of-here
ryan
out-of-here
ryan
5.0 Mustang Man
10-21-2008 02:50 PM
1TONY1
01-28-2005 09:38 PM
john@dps
19
12-30-2004 07:10 PM
Big Bob
12-24-2004 04:10 PM
swansong04
19
11-06-2004 09:42 AM
