Jake Brake and EGT probe
Like blue dually said, I think they all do. I cant say for sure about the 03-04 set up as I used a 04.5 and up on my 03. But if you use it as your only point of measurement, allow some room for temp differences. Pre turbo will give you a more accurate reading than post.
I don't believe the Jake on my 03 has a port, but if I recall there was a flat spot that looked like it was intended as a place to drill and tap. (I also put mine on the manifold).
I think 04.5 and up came drilled and tapped, with a plug.
wvcowhauler
13
04-03-2005 11:39 PM
Maccandy
04-22-2004 06:44 PM
