Jacobs Switch Loose?
I have a dealer installed Jacobs brake. The shifter mounted switch is a bit loose, it spins around the shaft with moderate pressure. I tighten the clamps screws and its a little better, but I would have expected the switch to be clamped down tight. I wanted to check with you guys before I complain to the dealer.
Its a manual shift. Appears one of the clamp screws is stripped. If the dealer left the bushing needed for the auto in, would it be loose?
Thanks.
Thanks.
Leaky Gasket
08-14-2008 07:17 AM
Nevada
03-30-2003 06:24 PM
