ISSPRO turbo temp monitor
I'm trying to install this device and need to determine which wire on the ignition circuit I need to use. The wiring diagram that came with it just shows a simple instruction and doesn't specify which wire to use in the ignition circuit.
Has anyone wired this up before and can help me determine which wire I need to use to splice into the circuit? Thanks, I have a 2007 2500.
unsure as to which wire it is you need but if you figure it out please post the details, I like the concept of the cool down timer?
BlackSheep5
13
04-04-2007 11:15 PM
bpdp379
02-17-2007 01:35 PM
rattle_rattle
06-28-2003 11:48 AM
