isspro gauge under the hood? thoughts..
im thinking of going back to my 3 gauge pillar pod. i dont want to mount 4th gauge on the steering column or in/on the dash. i was wondering if there would be an issue mounting my fuel pressure gauge under the hood? id run enough slack in the line that i could read it if i pulled it out from under the hood. i was think a single gauge holder like they sell on genos would be suffice. being its an isspro and its mechanical- there is no need to run any power to it correct?
Power would be used for the backlight.... Are you mounting it in the engine compartment? I don't know how that gauge would help if you fuel pressure dropped? If you want to eliminate a guage, I think they make a (red) light that can turn on once your pressure goes below a preset mark?
no biggie, then just put it in-line with a tee. cant speak for your brand of gauges, but i have had an autometer fuel pressure guage mounted under the hood in my mustang for 15 years, still works fine, no issues to date.
Tom
Tom
I would suggest some type of liquid filled gauge for under the hood
on my old 01 I used a under hood gauge..it was like 10bucks from my local Grainger..worked great for the most part..but I LOVE seeing whats going on all the time ...not just every now and then.
.02
.02
I have a low pressure light w/ my Raptor 100. Kicks on w/ 5psi or lower. It is the BD Low Fuel Pressure light. When I swapped my BD Aux Lift Pump w/ the Rator 100. I left the light in as a indicator on my tripple pillar.
I have pretty much what you need from some old MITUSA kits we had, If you can find a light you wanna use. I have the hobbs switch. Still planning on coming down for the valve body swap or did you get it strait already?
Brett
Brett
nope still plan on coming down for the valve body job. gimme a couple weeks, out of town next week and family is moving
