Isspro Fuel Gauge question
I am getting ready to buy gauges for my truck. I think I have decided on the Isspro's because I like the illumination on them at night. The only problem I have is the fuel pressure isolator (vs Autometer's electric fuel pressure gauge). Are the isolators reliable? I was going to use a tapped banjo bolt to go to the feed side of the CP3, anyone know what size stainless line I should get, or should I just wait till I mount it and see how much I need? Any other comments about the mechanical fuel pressure guage vs the electric fuel pressure guage?
Oh and since I forgot to mention it, I am getting Pyro, 60lbs boost and obviously FP.
Also I was going to order from Geno's because I was going to get a 4/2/1 kit as well. or is there anywhere people would recommend over Geno's such as Diesel Manor or any others?
All input is greatly appreciated.
I'm about to take off my gauge. I don't know if the isspro uses an isolator with fluid (mine is anti-freeze) like the diprocol. It transfers a noise into the cab. Almost like a Ford power steering pump noise on a cold morning. I would try to get an electrical isolator.
Go mechanical. Less hassle.
CRX, I get my filter from Genos now too. I just buy sets of oil and fuel, I don't run a stock air filter anymore.
FWIW, I had a good expericence and got a good value at Dieselmanor.
Got Isspro gauges, the kit they send you with the gauges is put together very well and the instructions are sweet. Color photos and all, made it very smooth install for me.
I have the ISSPRO fuel gauge. I have no noise what so ever. I will say this though. I read somewhere that if your isolator is less than 6' away from the gauge, you don't need antifreeze. I have nothing in the line and it seem's like it's working fine. How ever. I talked to a diesel shop and they told me my gauge won't work like that. So who know's. Guess I better put something in there so my gauge will work. BTW,,,I have the 36" line from the CP3 to the isolator. It's a little long, but I don't know what the next size down is.
I havent delt with genos but I have heard nothing but good things about them, however I got mine from dieselmanor. There can NOT be a more complete kit out there, great service too, 36" ss line from filter to isolator, also it depends on where you want the isolator. Talk to David he'll hook you up. After all is said and done tell him you want for 400 shipped and see if genos can match it. But dont forget to include the boost bolt ss line, isolator and everthing else. Other places I called left these item out on the price and still werent but about 50 bucks cheaper.
Can anybody confirm for me as well about the extras that are included from Geno's. If the Diesel Manor kit is more complete then I will likely order from them. Also where have people been mounting the isolator? Just trying to have it planned out in my head before I go to do it.
Ditch the isolator and go straight to the gauge. Put a needle valve in line somewhere and you'll be good to go.
Isspro (or) Di Procol - Boost, F/P, Pyro with every since connector (boost bolt, tap for manifold, sta-kons, heatshrink, wiring harness, zip ties, bulb covers,fuse, etc) $318.00 shipped.
Keep in mind this is a mechanical f/p gauge so I had to get about another $10.00 in parts to hook it up.
Can't speak for Genos, but I can tell you that Dieselmanor's website is far superior.
So other than a few fittings needed from hardware store the kit from Diesel Manor came with literally everything then?
Can anyone comment on what all Geno's kit comes with? I still want to get the 4/2/1 kit and shipping will likely be more economical if I just get everything from one place...however if the kit from Diesel Manor is better than Geno's then I guess I will have to break up the order? Any other suggestions or comments?
Likewise does anyone with Autometer gauges have any arguments why they would be better to get?
Well, it was only a few months ago, no special deal either, straight pricing.
I backed out the isloator ($65.00) and added a can of paint(forgot to mention last post) for the pod, and the 1/8" NPT tap.
I already had my bit and tap but DM will send that too if you need. Kit was COMPLETE I had to buy nothing but the kit I "made". The 349 is no ss line, boost bolt and maybe one other thing but David will tell you exactly what you need and send it too you, even the tap. 603-497-2281 Give him a call and see what he can do. Mine was a little over 400, with the isolator, ss line, boost bost and shipping and I got it for 400.
I mounted my isolator on a lip on the top of the firewall, it has pictures in the instructions, but I fabbed a plate to make it more strudy.
I also wouldn't put a fuel line straight into the cab. That's just asking for trouble.
Bad Ramer Jamer,
Is that isspro pyro gauge easy to read at night? How about with the dimmer all the way down?
Bad Ramer Jamer,
