Intermediate Shaft
#31
dang you tritont... i was hoping to get my output shaft in and be done with it.... o well guess ill start saving for a intermedate... i hate how i built this truck, with spray im around 900 hp but i cant use any of it because i built power first and now im building the truck to handle it. ive had this truck built with this power for over a year now but im to scared to bring it to the track to se what i will run sence its not built to handle it. o well quess ill stick with my dyno's till i get my truck built up... thanks 4 the help tritont.
#33
A member of another forum had a built tranny with billet input, stock intermediate, and billet output. His billet input broke before the stock intermediate.
Cquestad, did your truck have an exhaust brake when the stocker broke?
#34
Never an exhaust brake...
That is common too..input first...even if it "stronger" than the intermediate.
I guess all I and Tritont are saying...IF the intermediate goes...you basically throw away the tranny. So 750 more...is worth it.
#35
whats opie shafts? im not skipping corners in the tranny was just trying to find out if i did or didnt not need to spend the money on the interm shaft. my trannys as of right now has suncoast converter/vavle body, billet flexplate. billet input, billet output(not installed yet), clutchs, deeper tranny pan, trany gauge, so last thing will be the interm if its suggested. i just want to find out if i need to spend the money or if big hp guys go without them.
#36
My tranny has the sun coast extreme kit, BD Valve Body, TCS Triple convertor and my OD unit is completly built up. I put down 649HP on the dyno. I have a BD Flex in the mail and will get it installed soon. I am also doing an input shaft at the same time. I have never raced it at a track and don't do 4x4 launches so I can't see replacing the intermediate shaft. If i do head for the track i am not going to do 4x4 boosted launches, just 2wd and 10psi. I do have a lock up switch but once the truck is going I SEE NO problem using it. I know alot of people with stock shafts and built trannies running like I do with no issues yet. So for me I see no real issue with the shafts, yet. But for piece of mind the input will be done with the flex.
Dr.Kayak
05-18-2006 05:32 PM
gunracer1
01-16-2006 06:29 PM
Big P
12-06-2005 07:07 PM
OHFarmboy
02-25-2005 11:30 AM
Gear Poet
07-31-2004 10:16 PM
