intake and turbo questions?
I have a an auto tranny with ddp 90 injectors, 150 fass, 5" exhaust, smarty s with ts mp8. wanting to hit 700 hp what intake system and turbo would be best for me?
I have read that there is not much to be gained on the intake side [ even though there are things you can buy for a lot of money & look good , some testing has not shown much improvement ] .
But a bigger turbo would be called for , somewhere a while back I saw a chart showing many turbo's and HP levels for each , I lost my copy and not seen again , but maybe with this post someone will bring back , It would be a good tech. sticky .
DTR 1st Sergeant
Silver bullet minimum for single turbo, twins would be better. Stage 3 cp3 and even then with the DDP90's it will be tough. Possible, but unlikely. You don't have your sig filled out so it makes a difference if you have an 03-04 vs 04.5 and up... because you have a better chance of hitting your number if you have the latter.
More likely to be in mid/upper 600's either way provided you have the necessary supporting mods.
Taquache
21
06-24-2012 03:11 PM
natlchamp2k4
03-13-2007 05:47 AM
dodgezilla04
07-01-2006 01:28 AM
gman07
04-15-2006 08:32 PM
