Intake tube baffles !!
The x baffle in the tube from the airbox to the turbo, can i take it out and will it make a difference in hp or turbo scream? If so how do you take it out?
I pulled mine and didnt notice much of a difference. Maybe a tad louder but i dought it. I figure that it couldnt help airflow so I ganked it. I took it out by removing the housing from the trck. Then carefully sticking a small set screwdriver between the 2 pieces that make the plastic tube and carefully twisting the blade till I got all the way around. Kind of like using a P38 can opener. Once I got all the way around it pretty much popped apart allowing me to pull the cross out of the center of the tube. I put a few small drops of model glue on it and put the 2 pieces back together and reinstalled it on the truck.
dslpwr81
05-01-2008 12:54 PM
