Intake fan!!!!
#31
Intake air!
First thing about a diesel is Air in and Exhaust out. Put big air intake on is better and open up the exaust the bigger the better.
So of you don't make any sence or cents. It takes air to get power as well as fuel.
Can you actually get to much air? At what ratio does a diesel get to lean? I can't thing of anyone ever saying on this forum that they had to much air coming into their motor.
Now hold on I can deffinitly see that at Idle I can push to much air in with the intake fan. But as soon as a little throttle is applied the fan is just eliminating the the filter restriction. If a plugged filter can cause a decrease in performance why can't a no restiction filtration system give you power and economy. You guys that talk about blowing smoke at low rpm, if you had enough air it wouldn't be smoke would it. Why would you need a second turbo if it wasn't for more air.
I think with this intake fan, I could go to a bigger single turbo and not have the lag problem that is talked abut. Is a bigger single going to get better ecomomy though?
#32
Originally Posted by boostjunkie1
Yes I know that it is an Air Pump!
BUT:The removal of any gas (Oxygen) from a particular space is considered Vacuum, so during the entire combustion cycle there is in Theory a Vacuum that is created.
I'm done!
Please let me know why a Diesel needs a seperate Vacuum Pump?
I'm done!
Second, the term is messing up your thinking about how things work.
And so many things rely on this simple princable. Propellers, fans, engines, and so on.
Like stated by someone else, a true vacuum can not be created on earth. So all you have is realitive pressures. It is like it being -20 degrees outside. Yes it is below zero, but there is still heat energy in the air.
Or you take two air tanks and connect them together with a shut off valve between them. Say the valve is off, one tank has 50 psi the other has 100 psi. If you open the valve the tanks will equalize. Not because the 50 pound tank is sucking the air to it, but because the 100 psi tank is pushing the air to the lesser tank. That is what I mean when I say on earth it is all realitive pressures. Everything is under pressure, it is just a matter of how they relate to each other.
So when someone says there is 20 inches of vacuum there, all they are saying is there is 20 inches of less pressure in relation to atmosphere pressure.But there is still pressure there. If a vacuum guage's zero mark was at a true vacuum you would see everything is under pressure. But zero is atmosphere pressure.
If you could put an engine in an oxygen rich enviroment that had zero atmospheric pressure it would not run. Because the pistons don't suck the air in, atmosperic pressure pushes it in.
Fans and props create low pressure zones, and higher pressure hurries in to equalize the zone, hence creating flow or movment.
Now one guy mentioned you can't put more then 5 gallons of water in a 5 gallon bucket. That is true. Because you can't compress a liquid. But you can compress air. So you can keep putting more air into a certain area. Up to a point of something exploding of course.
So how does this relate to the subject at hand? Simple, knowing how this all works, you will understand the only way the fan in the air box will work,as he describes, is if it is pressurizing the air on the intake side of the filter more then atmospheric pressure. In which you can your own conclusions from there.
#33
Didn't somebody try this with a weed wacker and a honda civic?? Don't think it added any power to it, and that's adding pressure to a non pressure application. I understand what your trying to say, but your only going to put so much pressure into the engine. A cooling fan is built for volume, not pressure. Any excess air you get in there will just blow back out of the filter.
This brings to mind the whole air plane on a conveyor belt. So if it had a fan in front of the turbine, it would be able to take off??
#34
#35
When a piston pulls down in the Cyl, it does not hold any more than what that volume of the Cyl can hold. UNLESS it has some sort of forced induction on it.
That fan will not even come close to clearing up the smoke before spool up. The fan you use is VERY inefficent for compression like stated before. It will move air...but when you put a restriction on it...the air will bleed back through the fan. Its just not designed for it.
Tell you what....why dont your dyno your truck with and without the fan...and let us know what you find out. Take 4 runs with, average them out, and let the truck cool. Then take 4 runs without, average them out, and see what you get. I dont think you will see any gaines.
Get a TAG and an AFE stage II Intake, i think that will work better for what you are tring to do.....
#36
You are absolutely right on not helping or at least without a dyno proof. Seat of the pants and mpg wise doesn't show anything except on take off it pulls off the line a lot harder. Only gone 2000mi since the install and no adverse effects. I've tried it with the fan removed from the air box and mpg at this point I can't tell any difference. With the fan in it pull lots of water into the air box if its raining. Intake air temps do show to be cooler most of the time. Deffinitly cools the intake air temp faster after a short hot stop. I can't tell that there is any more boost pressure at normall driving yet. What do most trucks boost levels run at 65mph cruising, level ground no major head wind?
#37
Yes a leaf blower works click here
Only because a leaf blower will actually compress the air, a fan will not.
The fans that are being sold as "electric superchargers" are just fans used for ventilation of a boat engine compartment.
#38
Yes a leaf blower may work on a NA 4 banger small displacement gas motor.....Stand by for pics of a Leaf Blower straped to my hood with a NOS bottle tapped to the side......its going to be the newest thing.....who needs twins.....
#39
You just need a bigger leaf blower. (i didn't say it was a good idea, i just said it does work) I have seen a NOS bottle bolted to the hood of an old POS muscle car. I was impressed.
#40
Well as you can see I did get to the dyno and the graphs are in my photo area. You can make your own conclusion. As you can see in my signature I think it works.
#41
Spool up can be aided by air being forced over the compressor wheel...
Does anyone know why twins work? ;-)
I don't think the fan is big enough to do much...but it most likely did what his dynos showed.
MmmDieselFumes
09-27-2007 06:44 PM
MmmDieselFumes
09-27-2007 03:04 PM
