Installing Cooling mist TIPS?
Old 06-02-2008, 05:14 PM
madhat's monkey boy...
matego's Avatar
Hey Jrussell, can you bog yours down even at higher boost levels (over 30 PSI)? Maybe I need more water because I know I can crank mine up all the way and as long as its over 15 PSI boost it will not act up. Maybe I will call and get one of those big honkin nozzles.
Old 06-02-2008, 05:51 PM
jrussell's Avatar
I was just barely able to bog mine starting it at 15psi, but that was with a 12V 1st gen. I usually ran it starting at 18-20psi and then it wouldn't bog.
It sounds like your's is right on the edge...which is exactly where you want it. You could always try a larger nozzle since they're easy to change, but I think that will reduce system pressures and then it won't atomize as well.
Old 06-02-2008, 07:43 PM
J Double's Avatar
Although not a cooling mist controller, it is an option for mounting.
Ball mount from Ram Mounts using heavy duty double sided tape.
Attached Thumbnails Installing Cooling mist TIPS?-5535_5555mounts0006.jpg   Installing Cooling mist TIPS?-5535_5555mounts0004.jpg   Installing Cooling mist TIPS?-5535_5555mounts0003.jpg
jrussell
06-24-2009 09:24 PM
mulisha
05-31-2008 02:43 PM
Coal Train
03-17-2008 03:57 AM
rbrettctd
10-24-2007 12:37 PM
RamNu2
05-04-2007 10:29 AM
Quick Reply: Installing Cooling mist TIPS?
