installing CB radio
Old 06-13-2005, 11:32 AM
CarolinaThunder's Avatar
Northside of charlotte on the huntersville side. You can usually find me on 1,6, and 8. I'll give you holler when the skip starts to roll.
Old 06-17-2005, 05:28 PM
ram350013's Avatar
Powerstrokin',
Mine is doing the same thing that yours is. I am gonna try what they all said to try and hope that it works.
Old 06-17-2005, 05:30 PM
powerstrokin03's Avatar
good luck let me know how it turns out for you.
Old 06-18-2005, 12:46 PM
2k3 ctd's Avatar
I think that you might be on the right track concerning RF overload to the ECM..If you have that coax Anywhere near a bundle of wires to engine/computer you are inviting problems..I learned the hardway in a 95 Lincoln Town Car..I was running 600 watts on 40meters through a bumper mounted Homebrew Bugcatcher on a 12 inch form with a capacity hat and 60 inch wip while traveling..As I was approaching the redlight at the town square in Bellville, Tx I was transmitting and thr RF overload saturated my ABS and when I was applying brakes the ABS started stabb braking to the syllabic rate of my voice..
First, Isolate and run power direct from battery, Second try to distance coax from critical wiring, Third Ground that Antenna..I Have a headache rack and at top between cab and rack I ran 2 inch ground braid from bare metal on rack to behind rear brake cab light mount bare metal, then treated all for corrision prevention..And the Last and most important, Try to Bond all large metal surfaces, hood, doors , radiator support and bed with ground braid..This will eliminate 90 percent of your RF woes and increase the ground plane Performance of your antenna..
Hope this helps
dahdidah
I am outta here
RJ
Old 06-18-2005, 02:16 PM
^^Knows what hes talking about!
Mike S.
27
04-19-2007 09:45 PM
BigDiesels
15
08-23-2006 11:20 PM
twhman
06-07-2006 07:29 AM
Bullmoose
12-20-2004 11:48 AM
Commatoze
04-21-2003 12:30 AM
Quick Reply: installing CB radio
