Installed FASS and Vent Kit Last Night, Obsevations and Questions
Old 03-04-2006 | 03:26 PM
PsRumors's Avatar
First off, will the push and lock connectors hold? Seems there could be better ways. How were you able to get them to seat all the way, I have one that I have pushed and pushed and it aint going, yes I used some oil on it.
Second, anyone notice ALL the little spaces rust is going to setup in? This is the first time I have spent any major amount of time under the truck and it appears there are quite a few spaces (nooks and crannies) that hold dirt and moisture. Guess I will be sliding under the truck a few times a year to clean it out.
Third, what a pain to mount that pump (whole system). That was the longest part of the whole install. I am going to look at having a braket made that will allow the system to be mounted horizontal rather than vertical, should this hurt anything?
I ran 50 miles past empty and there was still 9 gallons of fuel in the tank, no wonder I have only been able to squeeze 28 gallons in the truck.
I haven't driven the truck yet, but will do a test run in the AM to the fuel station to see what I can get in it.
Old 03-04-2006 | 07:06 PM
Rick D's Avatar
Yes the push locks will hold, if they are on correctly you can't pull them apart.
I think think the water seperator has to be in th vertical position
Rick
Old 03-04-2006 | 07:16 PM
PourinDiesel's Avatar
Yeah, I agree the push locks will not come off.
You couldnt pull one off if you tried (even if they are not on all the way).
Old 03-04-2006 | 09:05 PM
Scotty's Avatar
Top's Younger Twin
...and do not put clamps on push lock hose. I have mentioned this to a few folks...they want some sense of security and go ahead and put the gear clamps on anyway. Does not take much for that to cause a leak and cut the hose.
Old 03-04-2006 | 09:16 PM
Geico266's Avatar
I hear ya Scotty, but there is no way I'm putting a fuel system togeather without hose clamps. I just don't over tighten them, I use two.
Old 03-05-2006 | 12:22 PM
PsRumors's Avatar
Well, after driving the truck it is noticably quieter and smoother. I filled up and was able to get a total of 39 gallons in the tank. That should put me in excess of 650 miles in range.
Old 03-05-2006 | 12:31 PM
rjm022's Avatar
i am thinking there is a better way to mount it too. when the weather breaks and i drop the tank to due the fuel tank vent mod- i will look to see if there is a way to fab a bracket that can mount to the frame to hold the fass, instead of mounting it to the spring perch.
Old 03-05-2006 | 03:34 PM
Scotty's Avatar
Top's Younger Twin
After having a few mounts mounted down low like near under the floor on the frame by the drivers seat and back by the rear axle, I have decided to put a prefilter and the pump in a nice, shiney aluminum checker plate box in the bed ahead of the drivers side wheel well.
Sure its a bit of a pull upwards but its not a lot and then gravity back down will assist with the flow to the factory filter housing with this set up.
After many different pumps and seeing what commonly fails, I will always prefilter before any pump from now on.
Scotty
1STGENFARMBOY
04-05-2010 01:25 PM
Spooler
25
01-15-2008 01:56 PM
afoulk
08-18-2007 04:33 PM
NeedMoPower
09-07-2005 09:43 PM
fitzydog
17
10-11-2004 12:36 AM
