Install help on headstuds
Well ill be doing my twins/fuel system/ and studs in the next 2 or 3 days and i was wanting some last minute advice for doing the studs, what to torque them to, what pattern to put them in(im leaving my head on) and how many miles should i go before i retourque them, their haisley 12mm's if that matters. Thanks in advance, i just want to do it right the first time
Use ARP Moly lube on the studs. Torque the to 118 lb-ft. Once installed, warm the engine fully then pull everything off and retorque. Retorque again after 500 miles. You will have to grind a notch out of the back of the "rocker box" to clear the back, center stud. R&R the studs in the order listed in the service manual (start in the center and spiral out). The 6 longer studs go down the exhaust side.
Should i be easy with the boost for the first 500 miles? Bye the way how long will the install be(including pulling everything and retourqing), i have a guy helping me thats done this a few times but i need to know if i need to borrow some transportation.
It is important to take your time on the head gasket, with all the boost and compression, it is one of the main problems people have.
On your first bolt start at about 60lbs the second to 60lbs, then torque them to 118lbs. You will pull the side of the head down and crease the gasket, if you start cranking on the first bolt.
Just keep the head as even as possible.
I have done some for trucks running 100psi, by doing two bolts at one time (me and a helper) going the same speed, same amount of turns, so it is perfectly mounted.
DTR Advertiser
That is a hard question. Depends on drive press, timing and boost actually. If you allow the motor to warm up fully and run a charger larger than stock( lower drive press) 55lbs is no problem. I ran up to 77 psi on my stock 00 headgasket with no problem for 2 years and the common rail mls gasket is better. Sometimes you get a head that is not flat though and they will blow much easier, luck of the draw. Tim
ARbowhunter7
02-19-2011 04:10 PM
SilverHoss99
11-18-2007 08:56 PM
Jetpilot
03-23-2006 01:45 PM
