Install Gauges? EGT/Pyrometer
I am looking at buying and installing a set of gauges for my 07.
Auto Meter
Pyometer/EGT
Trans Temp
Boost
My question is how hard are they to install?
I know the Pyometer/EGT gauge you need to drill and tap.
Thanks
Auto Meter
Pyometer/EGT
Trans Temp
Boost
Thanks
if you are some what mechanically inclined you shouldn't have a problem. Most kits or gauges come with all the instruction you need to get the job done.
One suggestion.... you might want to look into Isspro or Dipicol gauges as they both match the OEM cluster and both emit green light like the OEM gauges.
this is a great place to make your purchases. One reason being, Geno's makes sure you have everything needed to do the installs. A banjo bolt is one thing that most will charge you extra for. It comes with Geno's gauges.
http://www.genosgarage.com/departments.asp?dept=192
Autometer's are ok.. I am installing mine right now.. I would recommend buying the kit from geno's or diesel manor.. I bought mine locally to support the small town shop but coulda saved money and bought the Issso's of Dipro's from Dieselmanor for about half the cost.. by the time I get all the rest of the crap to install it... Autometer's are good guages though I like them ...
They are fairly easy to install..
Shane
Shane
Kman9090
29
12-06-2007 06:43 PM
coontz0473
17
09-22-2006 03:52 PM
