Install Commander & wait on Xzillerator or...?
Wait till I till I have the Xzillerator STD and install both at the same time?
(couple of weeks till funds available for box, also DManor cooler line to arive shortly)
Was goin over the Commander install guide and looking at the spots on the truck were all the hookups are, and thought maybe I should wait till I have the module so I'm not pull'en wires twice.
Or no big deal to install Xzillerator later?
TIA, Tom
TIA, Tom
The only thing you would have to change when you add the Xzillaraider is the boost tap. It should take you all of 2 minutes.
If you have the Commander I would put it on now and get used to what they truck does stock. That will give you a good baseline to go with after you add some power to it. Even if you wanted to leave the boost line unhooked you can still watch EGT, tranny and coolant.
Quad
Quad
adamsmarshall
04-22-2007 11:52 PM
adamsmarshall
04-19-2007 06:55 PM
