Injectors to hit 750hp
Old 04-13-2008, 01:37 AM
mudslinger's Avatar
I am running the mods in my sig, and I am looking at getting Lloyds' dual pump kit. My goal is to hit around 750hp. What size injectors would be best to hit my goal? I am thinking F-1, but open to suggestions. Thanks for any opinions.
Old 04-13-2008, 05:53 AM
Hintz's Avatar
I believe someone on here did 750 w/ TNT tune and flux 2.5's
Old 04-13-2008, 09:48 AM
DTR Advertiser
Don M's Avatar
What turbos are in the PDR kit?
Old 04-13-2008, 10:19 AM
king d's Avatar
i hit over 750 with stage 3 ii injects
Old 04-13-2008, 10:46 AM
RamNu2's Avatar
Don if you can pm about my injectors they were sent a couple weeks ago I can give your more info then.
Old 04-13-2008, 02:41 PM
mudslinger's Avatar
hybrid hx35/40 over ht3b. They should make the power, if they get a little hot I will make adjustments there as needed.
Old 04-13-2008, 02:43 PM
mudslinger's Avatar
Don I was thinking flux 3-3.5, what do you think?
Old 04-13-2008, 02:49 PM
DTR Advertiser
Don M's Avatar
Yeah, the 03-04 needs a bigger stick to get to 750 than the 04.5 and up does. The 04.5 and up could do it on 2.6-2.7, but the 03-04 would need a 3+. I think with the turbos you have a 3.5 would be best. Yes, it could get hot and the back pressure might be slightly high as well.
Old 04-13-2008, 03:03 PM
mudslinger's Avatar
thanks for the input
Old 04-14-2008, 09:47 AM
nottanuff03's Avatar
if you dont mind me asking what is it about the 03-04's that make them need a bigger injector than the other years? Just curious, thanks!
Old 04-14-2008, 10:14 PM
mudslinger's Avatar
the 3 injection event guys have always been a step ahead, I am sure Don as a technical reason why...
Old 04-14-2008, 10:22 PM
Summit's Avatar
i made 747 last year with Flux 3's. on a 555.
not to highjack,,, Don i got after it today, inj. only, and a tiny bit o rail, === thanks man, ill have a # soon
Old 04-16-2008, 11:27 PM
mudslinger's Avatar
That's sweet man, I know it's a bit of a dumb question with fair sized stix, but how do you find your mileage?
Old 04-17-2008, 12:05 AM
O.T
O.T's Avatar
Sling daddy what's up.....go for the 3.3-3.5 you will love em!
Old 04-17-2008, 12:59 AM
mudslinger's Avatar
Is there any truth to only losing a mpg or 2, with moderate injectors? I know that dual pump fuel supply is supposed to help that as well...
I can't catch up, but I don't want to be too far behind you
Quick Reply: Injectors to hit 750hp
