Injectors and emmisions?
Was thinking about getting the DDP stage 1 injectors when my stockers start to give out since they have an available SS body. I was just wondering if I will still be able to pass emmisions with the better flow of the injectors even with my power adders removed for testing. Anyone have experience with this?
I failed the snap test several times with my "extrude honed" F1's, but it was with a slow spooling Silver62.
From what I have noticed, most people who start off with DDP stage 1 injectors, end up with their 90's. You may want to consider them to begin with, You still should pass easily with your stock charger.
JJ
Yeah I had thought about the 90's but I have been told by several people that at 5,280 ft which is the altitude here in denver it easy to put in too much injector and that its not necessary to go that big.
The 90's aren't bad at all here, I woukld say they run a smidgen hotter then at sea level, but every car is fighting for air up here!
no i just turn everything off and go down to Diesels Only off of Almieda, as far as the sniffers on the freeway entrance ramps just take it easy if you see them, because they will send you a notice to go to emmissions if your hot. I've always kept my stock tips until recently just in case i couldn't pass but always have. a little bigger turbo i'm sure would help to clean everything out a little more with no tuners on.
3Sigma
09-27-2006 12:35 AM
Palmetto_kid
01-18-2004 03:36 PM
Commatoze
12-17-2003 06:16 AM
