Injector Question
Injector Question
what is the best injector to go with for an 04.5. i have a quadzilla xillaraider intake and 5" exhaust. i'm going with and Airdog 150 to supply fuel, just want a little bigger injector for performance and a reasonable price. would like the whole injector, not just nozzles so i can put them in myself without pop testing them
I would try the stainless bodies thru wiked diesel. I think 300 each is what he had posted. I am on my third set and would definatley advise a 2 mic filter. The fass I have is a 3 micron and is still wiping them out. I think the revised factory filter is 7 microns so deal with that first. Good luck.
if you want the best injector then go with Formula 1 injectors. i know Don M is swamped with work but he has an awesome product. there are to many people on this forum running his injectors so that tells you something.
www.f1diesel.com,but if you actually want to purchase the injectors you will have to go through a F1 dealer. you can contact Tim at TRE Diesel Performance, great guy to deal with.
I haven't tried F1 but have heard great things. I got quoted a price from another place for 370 per stainless body, and I seen shane had them for 300. If you don't want to change your own nozzles then contact TRE or Browns, they have a sale going on right now for flux nozzles. I would not just change nozzles either, get them balanced and in one piece. Every injector is different so they do need balanced to make it right.
TJ0993
11-08-2007 10:27 AM
gablekevin
09-19-2006 12:12 AM
kawi600
01-26-2006 10:19 AM
oscaroc
04-02-2005 12:14 PM
