injector nozzle size
hey guys, its time for me to adjust my valves and when im in the process i want to put arp studs and nozzles in my truck. I plan on running it with the he 351 for a little while and know i need more air, but do not want to buy small nozzles then after i get more air have to go to a larger size. So what nozzles should i go with. i like the price on wicked diesels 180hp mafia nozzles but dont think i have an adequate setup to run them. I plan on building my truck to around the 600hp range. any suggestions appreciated
180's are definitely overkill for 600hp. With your '03 90hp nozzles, BD SuperB Special, Arson III will put you at 600hp.....maybe a little more. You could run 120's with the Special, but it may get a little hot.
EDIT. Just saw that you have an '03, the 120's may suit you better
CamperAndy
05-09-2009 11:56 AM
93Fury
01-25-2008 11:56 PM
