Injector Nozzle Install
Old 10-17-2007 | 04:45 PM
sliqwille04's Avatar
I bought a set of Scheid nozzles from a member and I am about to install them. I don't have a removal tool. Do I need one or is there anything that will work in its place? If not, does anyone have one I can use or purchase? I'll pay for shipping and a resonable amount for someone's time involved. Thanks for the help guys.
Old 10-17-2007 | 05:16 PM
emfc_22's Avatar
when i do them i take the part that the bolts go through and just clamp on the two flat sides in bench vise. the body is machined that part is just a block or spacer, i do know that all the twisting force will be going on the little dowl pin on the body when doing this though. but i have done over a dozen sets this way and no issues yet.
Old 10-17-2007 | 06:34 PM
PourinDiesel's Avatar
I wouldnt rely on the pin. Good way to mess up and injector.
You can use 2 pieces of wood with a hole drilled through them secured in a vise. You can also machine down a 7/8" wrench and engage the flat spots on the injector body and secure the wrench in a vise (same thing the "tool" does).
Old 10-17-2007 | 08:53 PM
CReed's Avatar
Grind down a 22mm open end wrench and then clamp it into the vice. This will hold the body in the upright position and let you do what you gotta do. Retorque to 55ftlbs.
Old 10-18-2007 | 03:32 AM
josh brown's Avatar
Go to www.dynomitediesel.com they have a great write up on there on doing this.
Old 10-19-2007 | 12:30 AM
Thanks. I'm putting them in Saturday. Let you know hoe it goes
Big Dblue
06-26-2011 04:23 PM
dropped2500
04-21-2008 06:03 AM
93Fury
01-25-2008 11:56 PM
Dwitt0187
08-23-2007 08:54 PM
oestreich84
11-21-2005 09:22 PM
