Injector install help...
Old 02-14-2008 | 01:55 AM
Billm2004's Avatar
Question Injector install help...
How do i get the injector connector tube out without the miller tool, I started tearing down the truck to get the injectors in when they come in tomorrow, but i havent gotten to taking out the connector tubes, but i was wonder how to get them out with out the tool, is there a rick or is it pretty easy to get them out by hand?
Old 02-14-2008 | 02:08 AM
Dieselhed's Avatar
I wraped the ends of mine in a thick lint free towel, (wife get's 'em from the hospital) and took a pair of pliers pinching the ends for a good grip, and pulling them straight out. Piece of cake. Let me know if you have anymore questions. I just did this on the same truck and it's fresh in my mind.
Old 02-14-2008 | 02:35 AM
Billm2004's Avatar
thanks, i might hold you to that!
Old 02-14-2008 | 02:37 AM
Billm2004's Avatar
actually, how do you get the fuel lines out of the way of the connector. i remover the line brace/bracket, do i have to loosen the line at the rail too?
Old 02-14-2008 | 07:10 AM
Rpainter's Avatar
easier to remove the entire rail
Old 02-14-2008 | 07:56 AM
Bad-Duvall's Avatar
X2 on the movin the hole rail. and just grab the tube wiggel and yank they will come.
Old 02-14-2008 | 08:14 AM
jrussell's Avatar
Yeah, you should be able to pull them out by hand but they might be a little stuck the first time.
When it comes time to remove the injectors without the tool, there is a little trick I figured out. Pry up on one side with a screwdriver and use your other hand to hold the injector and keep it centered (while pulling up a little). They will pop out much easier than if you tried to pry really hard or used two screwdrivers together.
Old 02-14-2008 | 01:14 PM
Dieselhed's Avatar
Removing the rail is the way to go. Much easier to get in there and work and I didn't want to take a chance of getting any dirt in the rail.
Old 02-14-2008 | 02:23 PM
Billm2004's Avatar
5 down 1 to go! Thanks for the help, i didnt remove the rail just some of the lines, i hope thats not hurting anything. Im keeping them all clean and away from debris.
Old 02-14-2008 | 04:11 PM
jrussell's Avatar
Nah, won't hurt anything.
When pulling the rail you only have to remove 2 connections and a few bolts. Removing the lines is probably a little easier, but you increase the chances of leaking fittings. Not that leaks are really a big problem...assuming you don't under or over-tighten the fittings.
I bet you can't wait to drive it!!!
Old 02-14-2008 | 06:33 PM
Dieselhed's Avatar
Let me guess. That last one is #6? It's a $%&@$
Old 02-14-2008 | 06:57 PM
jrussell's Avatar
Let me guess. That last one is #6? It's a edit
I used a special tool for #6 and that made it really easy. In fact it was even easier than the other 5.
The special "tool" was my cousin who has an ASE certification and really long arms. Sorry, don't have the part number handy.
Old 02-14-2008 | 07:04 PM
Billm2004's Avatar
LOL.. DDP is overnighting me a set of new nozzles, but they also said that it could be possible that my injector body is messed up too. What could be wrong with it. my factorys ran perfect. i only have 65,000 miles
Old 02-15-2008 | 08:20 AM
jrussell's Avatar
What exactly is it doing? Mine had some sticking nozzles at less than 10k miles, but that shouldn't matter for you since they've been changed.
I really hate to say it man, but this is exactly why I like how Don at F1 installs the tips and then flow tests each injector before sending them back. It's a pain to have your truck down for 48hrs, but it helps to avoid issues like this.
Old 02-15-2008 | 10:11 AM
Dieselhed's Avatar
I agree. All 6 of mine checked out good, but having Don tell me that was worth the wait. Now I know for sure.
