If the FASS stopped pumping would....
The CP3 still be able to pull fuel through it? I heard this somewhere but I don't know if it's true. It sure would be nice if it were true....
I know when I use the new TST Turbo Cool Down Timer, the FASS is off while the truck idles and cools down. It has taken over 3 minutes to cool down a couple of times. So at least I know it will pull some fuel through it.
Originally Posted by RamWheelsBy4
I know when I use the new TST Turbo Down Timer, the FASS is off while the truck idles and cools down. It has taken over 3 minutes to cool down a couple of times. So at least I know it will pull some fuel through it.
My TTM will run the pusher w/o the key.
Cool! I guess I can just pull the stock LP off since I won't need it any more...
Wanna sell it? I could use a spare till I get cash for a RASP. I don't really want to go with the in tank set up since I will be going with a after market fuel system.
I don't think you want this one. It was only putting out 6psi max. It was dying a slow death....
You never know, 6psi may keep me from sitting on the side of the road. But obviously not a great candidate for a permanent replacement. If you decide to chuck it, give me a yell...
Vitamin C
03-26-2007 09:59 AM
