I want Pizza Cutters (tall skinny tires)
Old 09-17-2012, 12:58 PM
maddog1927's Avatar
About the best I could find in Toyo MT 285 / 75 / 17
They are 34.1 tall X 11.6 wide and 3195 Lb. rated.
I would like to go taller, but they start to get really wide.
Anyone got a good lead on something taller that doesn't go much wider? Doesn't need to be MT.
Also I hear the Toyo MT is quiet and last a long time, can that really be true, I am skeptical.
Old 09-17-2012, 02:41 PM
mgdoug3's Avatar
What about 255/80/17's? They might be 85's, not sure. They should be just as tall as 285's but narrower. I never has used a set so I don't much about them besides they are pricey. This is about the only tire I know that is tall (taller than stock anyway) and narrow.
Old 09-17-2012, 05:34 PM
jimbo486's Avatar
Toyo MT's are not quiet . Even their Open Country AT will produce some noise.
Old 09-17-2012, 05:47 PM
firgod4's Avatar
my M/T's are pretty quiet but then again my trucks really really loud so idk
Old 09-18-2012, 04:34 AM
jimbo486's Avatar
I suppose all that matters is that you can't here it from inside the truck.
Old 09-18-2012, 06:53 AM
MikeyB's Avatar
Stepping up to 19.5" rims will get you tall and skinny.
MikeyB
Old 09-18-2012, 10:29 AM
kry226's Avatar
That, or the OP could go 285/75/18.
Old 09-21-2012, 02:08 PM
FarmerJim's Avatar
What MickyB said and you can get load range F & G tires and the tread depth is great.
Old 09-21-2012, 02:44 PM
Fordzilla's Avatar
Correct...My 245/70R19.5' Michelin XZE's are 9.7 wide by 33.6 tall with 18/32 tread depth...I notice my LR "F"s are no longer available as well as LR "G"...Next time I'll either have to get LR "H" or switch to XRV's to stay with LR "F"......Ben
Old 09-21-2012, 06:09 PM
Fordzilla's Avatar
And if you just insist on staying with the 17" wheels, try this......Ben
Old 09-21-2012, 08:06 PM
Blake Clark's Avatar
http://www.intercotire.com/tires.php?id=7&g=1
Make sure you change em when you change your oil!
Ive been back and forth on tires for months now. The factory set is working on 40k and with my driving habits, are getting thin.
I guess 285/75/17 Open Country MTs are gonna be my go to tire.
Old 09-28-2012, 02:03 PM
BroncoAZ's Avatar
Nitto Dura Grappler and Terra Grappler are both available in the 285/75R17, so is the Toyo Open Country AT. I would go with any one of those over a MT, but I don't need the MT's. I have seen the 255/80R17 BFG muds on a couple of trucks locally. They looked a bit too narrow for my liking on a SRW, but they looked sweet on a DRW.
I've been thinking about going taller, but my stock size Michelin AT/2's are lasting great with 12/32 of tread remaining after 25K miles.
Old 09-28-2012, 02:35 PM
railroaderone's Avatar
could go with a 245 75 17 skinny and tall
Old 09-28-2012, 11:27 PM
bibbo's Avatar
i have mt's and i dident get long life at all... rotated every 3-5k and i have about 9 months and 12k miles on em towing on weekends and im down to the wear bars?? i dont do alot of burnouts either.. frankly im not impressed
Old 09-30-2012, 07:06 PM
Rednax's Avatar
Changing tire height ain't so hot for handling, braking and component life. Going skinnier than OEM definitely isn't good for braking, steering response either. Fuel mileage isn't helped either.
If there are those of us who regularly get above 100k on a set of OEM spec tires then it's really hard to beat the appropriate size.
MICHELIN (LTX series) or BRIDGESTONE (Duravis series) ought to be where you start & end, IMO.
Stock spec and pressures reflecting loads on premium tires = no headaches and lowest cost per mile.
The numbers in my sig are no accident. The right brand and size is central to a low cpm of ownership & operating costs where performance is always at least as good as stock.
Quick Reply: I want Pizza Cutters (tall skinny tires)
