I want to dyno.....But!
Hey guys i am kinda between a rock and a hard spot! I am wanting to dyno my truck this weekwnd but have a few concerns, i have stock lift pump, stock clutch, and a plastic IC! My smarty is the 4.11 w/ Wild TQM, do you guys thinkk i will be safe to go ahead or should i wait and get a few more goodies? If i do go ahead what kind of #'s are we talkin?
Smarty 4.11 Wild TQM
Araid Stage 2 intake
Straight piped
Thanks chad
Straight piped
Thanks chad
i have an 05 like you (plastic ic also), and just recently put down 520hp w/ tnt, htt turbo, FE clutch, stock lp, stock cp3, stock sticks(this was done on a dynojet). i think you'll be alright as far as fuel goes, however your clutch may slip w/ the wild tqm. Back in april i dynoed (on a superflow) w/ smarty 4.11 sw9, wild tqm, FE Clutch, stock lp, stock cp3, stock turbo, stock sticks, and put down 433hp & 853ft/lbs. if you dyno on a dynojet i think you'll be around 450hp & 900ft/lbs
Ok thanks guys i'm going to go ahead and give her a shot, we'll see what happens, i wish i had more fuel upgrades but for now......I hope my clutch holds up for the dyno, i run it everyday on sw5 and i can slip with ease if i hammer it, i'm hoping the dyno will not have as much load! I'll let you guys know what happens!
yeah i know, i figure what better way to talk the old lady into letting me get another but to blow this one up i have the wastegate set to 45psi so i think i'll be good as long as i don't turn it up much higher
Your stock clutch will hold just fine.
max out your Smarty and give all you got.
I would load up TNT sw9 and go WOT at 1600 rpm's in 6th gear.
If you do what I say you should be 440-460 whp
The dyno is easier on your truck then the street.
Whats the best way to get the TNT tune? I'm so computer dumb it ain't even funny, is there anyone close to me that can help me out i don't mind drivin a little ways, just don't make me drive to florida, i would love to have that tune! By the way i live in crittenden , ky!
withalligators
10-08-2014 10:22 PM
2171CTD
02-20-2012 04:16 AM
BigDan
31
01-22-2006 01:05 PM
PapaSmurf
12-19-2003 02:14 PM
