I need help with BOOST!
I put the Quadzilla BOOST FOOLER on reads lower with it on? What am i doing wrong?The only thing on this truck right now is the BDDLTRIP,DOG.Took the MP-8 off said you cant use the boostfooler the same time.Please tell i can run the MP-8 to!If i just run the BDDL by its self good boost right at 32 psi I was looking for a littel more so i bought the QUADZILLA to help till i get money for a new TURBO! THANKs
are you using mechanical gauges or a monitor of some sort. if you are using a monitor, the boost fooler may be fooling it as well, since it changes the voltage of the sensor output provided to the ecm
if you are using analog gauges, i'll have to think about that.
Highest ive seen with stock injectors, stock cp3 is been about 58-59. This weekend ill dyno with my new injectors, and the week after that with my floor it CP3(stage II) so ill let you know, ill also record my backpressures.
Oh yeah, only about 45 minutes away from the campus so ill be their for sure. I just wish i had the CP3 in mine already. How much boost are you pushing? With any luck ill soon have a custom set of garret ball bearing twins from my bros shop.
I dont know why i cant use the MP-8 for boost fooling. By its self i can. Thats why i bought the QUADZILLA BOOSTFOOLER! With the BDDL TRIP,DOG i can see 32.I thought the QUADZILLA BOOSTFOOLER would help!
Winner winner chicken dinner!
I have the quad boost fooler and bullydog. On the outlook with the boost fooler installed you wont see the proper boost numbers at higher boost levels. I think I only see 28-32 max, but on my mech gauge I see the real #'s of 55-60.
ahh thanks. and you are seeing the same boost reading on the analog gauge as the digital?
with the boost fooler you should be able to get above 40 no problems. start with simple things first. when was the last time the fuel filter was changed? what condition is the air filter? what are you egt's when running 32psi? and ensure that all pressurized intake boots are tight and on.
