I Keep Throwing Codes Help?
did you remove the waste gate controler off the stock turbo? i did at first and had codes then i plugged it back in and zip-tied it out of the way. no more problems.
see if it is plugged back in to something like what it was before. a shop should have put that resistor type plug in there so you dont get codes. that might be your problem. maybe they didnt know either but they should have.
Got About 300 Miles W/ The Tst And It Threw The Codes Again. Spoke To Somebody And Said That I Need To Remove Somthing From My Old Turbo Insatll It On My New And Ground It Out. He Couldnt Think Of What It Was Called And I Am No Mechanic By Any Means....any Help?
RAT_03
04-01-2007 03:51 PM
