I have my tax return and cant decide which box to get
I was wanting opinions from people owning 03 04's With Boxes. Whats the best combo? So far im leaning towards TST and stacking with my EZ. Id like to use more of a timing type box rather then keep abusing the fuel system with high fuel pressure all the time.
I second the TST pluz EZ. I keep my EZ on 3 so it doesn't increase the pressure too high. I think this is one of the best combinations for power and low egts. Some of the other chips that have GPS functionality are cool too, but the fueling isn't the same.
TST EZ Stack
A friend has this stack on his '03 and his EGT's Rocket fast. Truck pulls like a monster for a short period of time then the box cuts back the fuel because EGT's get to high. What is the deal with this. He has 5" exhaust, a cool air intake, and the TST EZ stack. Plus his Auto Trans has been replaced 3 times because he burns them up putting to much power to it. My question is, is this just a problem that he is having with his truck or is this common for this stack. If that is the case I would not recommend that stack because you really don't get to enjoy the additional power (However your truck will SMOKE LIKE A COAL TRAIN) and maybe just get the Juice Box with Attitude monitor. It will monitor for Trans slip and cut back power so you don't burn up trans so fast, EGT's don't get that high, plus you get to enjoy your power all they way through the RPM Range.
My .02
My .02
With my EZ on 3 and the TST regular program on 5/8 when I had the stock turbo, I could stomp my 6 speed from zero to 108mph and never get too hot. Maybe it's different with the auto?
My .02
My .02
The TST is sweet I Dynoed 420 hp 845 TQ on 6/6 7/7 my clutch was smoking, and then the enging was missing {didn't have the pusher pump yet}
Installed a Luke clutch , pusher pump and clutch slipps on 9/9 And yes, egts run a little hI
SMOKIN-U
10-21-2007 03:10 AM
04ctd
16
12-11-2006 11:21 PM
dodgetech77
12-02-2005 10:26 PM
Checkmate
04-05-2005 06:37 PM
