hy35 turbo
Tire Hater
You don't have to do ANY fab work. Simply run a line from your manifold to your wastegate with a bleeder "boost elbow" inline. The electronic wastegate can be removed and the hole plugged, or left sticking off the compressor, up to you. Hope ya understand..
Hold the phone here fellas! 03-04 has the hy35 right? 04.5-06 uses a different holset turbo doesn't it? Someone should straighten this out before bad info gets a guy in trouble.
Holset website
L8r,...........dogger
HY35 parts
Originally Posted by wldman32
thanks great info!so do you think the center section is the same?will a hy35 rebuild kit work?
L8r,.............dogger
SSweeney
11-01-2006 04:14 PM
