Hummer H2 and 315s installed
Thanks to all the helpful information on this forum I now have 315 BGF KOs along with Hummer H2 wheels installed.
Thanks to the poster who recommended using a router and trim bit to open up the center hole. What an easy an inexpensive way (if you already have a 1HP or better router), and its even easier with the tires mounted. I bought a 1/2 in frued carbide bearing flush trim bit for $14, set up the router such that the bearing was catching a bit of the wheel, flipped the wheel/tire over, good side down, and slowly trimmed around the hole clockwise. Five minutes later all four wheels were done. This is no sweat for anyone that's used a router, and I now have a nice stack of aluminum tinsel for holiday decorating. The router bit showed no sign of wear. The hole is just a knat's eyelash smaller than the OEM wheels and has a smooth enough finish.
The hardest part of the job was the dozen-sledge hammer swings need to break each rear wheel away from the hub. Truck is only 6 months old and I was surprised how seized up the rears were.
The KOs are much noisier than the OEM rugged trails. Without fender flares they sick out a little beyond the rear fender. On the road I can tell it’s definately a bigger tire under there and 2100 rpm is now 72 instead of 65 (according to my gps).
Did not take the time to take pics or wash the truck, had to get high schooler to a party and then team practice, then it was family movie night.
There must be hundreds of hummer H2/315 on a RAM pics posted already. I didn't think it was necessary or even worthwhile to show another. Maybe I can pull a wheel and take a pic of the center hole after routing, if anyone thinks that would be useful.
I agree with ColdCase.... there are plenty of H2 tire/wheels pics here and elsewhere. Unless he did something special, the truck isn't going to look any different!
is there a benefit to H2 rims other than cosmetics?? my buddy has a rim/detail shop and has stacks of em i can get cheap, but havn't seen a benefit other than a new look?
I'm getting ready to put on my second set. Got about 45K out of the first ones. I like the router idea. I did both of my sets a couple of years ago with a hole saw. Worked OK but had to sand it smooth.
I've heard, the wheels are pretty stong and durable, and the BFG KOs are a pretty good winter tire. For towing heavy I suspect the taller and softer sidewall may not do well.
Congrats on the new wheels and tires ColdCase. I run the same combo and absolutely love 'em. My truck is 2-tone with the silver rockers, the aluminums have the same silver powdercoat as the rockers, so it's a nice match and is complimentary. I have a second set of the chrome H2's that I plan to mount a set of more summer rated tires on - TOYO AT's. The H2 rims, both the chrome and aluminum, are weight rated in the same range as our stock steel wheels. I have used the BFG's exclusively on one of my other trucks, they tow heavy just fine as long as you air them up to the sidewall recommendation - 50#'s. They are an outstanding winter tire as well. I lived in PA prior to my recent move to NM, lots of lake effect deep snows, never had a problem. I have trucked around and past a lot of other p/u's stuck or traveling much slower with other brands of supposedly good winter tires. I have also gotten excellent mileage out of them. Again, the best tire I have ever used for multi-purpose driving.
Your 2006 truck would have/should have had clearance with them on the stock wheels. Lots of them out there on the stocks. The only problem that some have reported is that they seem to wear out in the centers faster. Some have suggested it is due to the slightly narrower wheel, could be. I would propose it also might be due to some running a lower air pressure than is recommended.
In any event, enjoy your ride and your new wheels and tires.
CD
CD
Actually, running a higher air pressure will wear out the center.
Coldcase, is your suspension stock? Any rubbing problems? I really liked your change in speed at 2100 RPM. I am looking foreward to slowing down the engine on the highway.
Sorry bout that... jeesh… I just figure I see a post with H2 rims and 315’s and there would be some pictures. We have talked about it enough… nice rim allows larger size blah, blah… Sorry but I enjoy looking at pics of nicely set up rigs. And besides DWiggs rig there really aren’t that many pics on the boards. True there are some pics out there but not that many. The truth is I wouldn’t make a post that said new headlights installed and then not put at least one picture of them. Sure there are pictures out there and sure they probably look similar but why bother. Sorry to have upset you it was not my intent. I am sure the wheels look good.
Pics will have to wait till the weekend, just not enough daylight. Sorry
