HTT turbo and check engine light
Old 03-12-2008 | 07:31 AM
Diggie's Avatar
I just installed an HTT turbo (62/65/13), and went for a test drive. Everything worked well, but when I got on it, my CEL came on. Is this due to the 40lbs. of boost?
Thanks for your help!!
Old 03-12-2008 | 09:25 AM
Spooler's Avatar
You may have the overboost code. Don't know. Pull the code using the key on off 3 times and post it or look it up on the DTR WIKI. You may not be doing boost fooling and that is causing the code. I thought an Edge EZ did boost fooling???????
Old 03-12-2008 | 09:39 AM
Diggie's Avatar
I tried using the key, but cannot get a code??
Turn the key on and off 3 times, then leave it on, and it should flash a code, right?
Old 03-12-2008 | 09:41 AM
rip 112's Avatar
Leave it on the 3rd key-on and look in the bus port (odometer window), should pop up some #s or say done when its done.
Old 03-12-2008 | 10:01 AM
staarma's Avatar
The 06 and newer are a little quirky. On my dad's 06 I have to do it lightening quick or it won't work. Cycle key as quick as you can amd it should flash the code in the odo window or if no codes are present it will say done.
Did you use the resistor in the wastegate harness that used to plug into the stock turbo?
Old 03-12-2008 | 10:07 AM
Diggie's Avatar
Yes, I used the resistor. I was playing with the Bully Dog, and I cleared the code. I'm sure I'll get it back, and when I do, I'll try and see if I can get the key thing to work. Thanks for all of your help!
Old 03-12-2008 | 10:22 AM
jmccart's Avatar
Do you feel a big boost in power with that turbo or what?
Old 03-12-2008 | 11:29 AM
Diggie's Avatar
the CEL is on again, and I did the key thing to get the code, but all that showed up was "done"?
Old 03-12-2008 | 11:30 AM
Bob Wagner's Avatar
is the truck in limp mode? "no power"?
Old 03-12-2008 | 11:45 AM
Diggie's Avatar
I wouldn't say "no power" but probably more like 75 to 80% power. I believe it is an overboost code, as it is fine unless I reach about 35lbs. of boost.
Old 03-12-2008 | 11:52 AM
staarma's Avatar
I see the EZ in your sig but is it hooked up? I'm pretty sure the EZ does boost fooling. I know the BD does not. The problem I think is your ECU is seeing too high of boost and it's setting a CEL. Usually when that happens your truck will go into limp mode like where Bob was going with it. It will stay there until you "fix" it with a reader or programmer.
Old 03-12-2008 | 12:12 PM
Diggie's Avatar
I think you are spot on, staarma. I will call EDGE and see what they say. If not, what programmer would you advise. (smarty?)
Thanks again for your help, Guys!!
Old 03-12-2008 | 12:17 PM
staarma's Avatar
No, any piggy back out there should boost fool or you could try the boost fooler from Quadzilla. I will be surprised if the EZ doesn't do any boost fooling. Most/all programmers out there don't boost fool. The signal comes from the MAP sensor off the intake plenum. It goes from there right to the ECU. You need a piggy back module like the Juice or TST to intercept that signal and then the module will reproduce a signal that is considered "safe" to the ECU so it keeps it happy. I'm not sure how the Quadzilla boost fooler works but a few guys have not had luck with them and had to go with an actual fueling module with boost fool to do the job.
Old 03-12-2008 | 12:33 PM
Diggie's Avatar
I just talked with Edge, and they said that the EZ DOES do boost fooling, and he thought it was in the Bullydog's signal to the map sensor. I am on hold right now with Bullydog, and will see what they have to say.
Old 03-12-2008 | 01:37 PM
staarma's Avatar
Good, at least it sounds like you're making a little progress. Might be time for a Smarty. The Smarty and the EZ play extremely well together.
buddy26
02-15-2008 12:17 PM
O.T
16
01-14-2008 02:47 PM
choppers555
10-16-2007 12:29 PM
Bobcat698
11-08-2006 11:20 AM
alltimelow1
04-06-2005 07:28 PM
Quick Reply: HTT turbo and check engine light
