HTT 71 stainless or Silver 62?
I've been searching and reading all day/night since I figured out that my stock turbo is hopeless. I'm running a 2003 HO, 6-speed tranny, with a quad race and BD tripledog with Crazy Larry (weaker than 04.5+ CL, however). I never plan on doing twins in the future, but I am thinking cam and injectors in the spring and I might try a TST. I tow occasionally and drive 130+ miles a day on the highway for work. What turbo should I get? I think I should get either the II Silver 62 or one of the HTT 71's, like a 62/71/13 stainless. Any suggestions? Comments? Experiences? Other turbo suggestions? This is my first turbo purchase and I need to get it asap because my stocker is nasty....
Thanks!
Andy
Thanks!
Andy
Lloyd Mills has an HTT 62/71/13 for sale in the classifieds right now. He's one of a handful of guys I'd buy a used turbo from. And that'd be a great turbo for your setup. If I had the money it would already be sold.
The Silvers are sweet turbos. You could easily run a Silver 64 without problems. I love the 74mm wheel. Some might think it's a touch overkill for a 62mm compressor, but this turbo does a great job of cooling and keeping the drive pressures low.
The HTT's are great turbos too, and I think they have ironed the problems out of their stainless turbos. I don't think it will be long before they bring a out a "Silver Bullet" of their own with a stainless exhaust housing.
HTT or II
Thanks!
Andy
Thanks!
Andy
If I were you I'd write down every mod you have and even those you anticipate in the near future and then call both of those companies and go over them and tell them how you intend to use the truck and let THEM TELL YOU which turbo. Everybody is a turbo expert,.. right,... let the experts tell you what you need for your application. I know at least on the HTT side that for a fixed amt if you added a lot of mods that they would mod your turbo to fit that application in the future,... I don't know if II does that. You can't go wrong with either one except for ordering the wrong thing,.. of course. My $.02
Back when the Super Phat Shafts came out, I was sold a 66. After much frustration, and eventually the purchase of a SPS62 I learned to trust my feelings. It turned out that on my truck the 62 cooled better than my 66 because it spooled earlier and would stay ahead of the EGT's.
I say, go with the smaller turbo and upgrade if necessary. It's a lot less frustrating than having a big, laggy, smoky turbo that surges when you're towing.
I think as long as you stay with a 62 you'd be a winner with either II or HTT.
I have procured a HTT 62/65/13 stainless so I hope that does the trick. I guess that wasn't on my list of options but it sounds like it fits my needs. I was thinking a 71 was what I would go for but they talked me out of it (HTT direct).
Andy
Andy
Turbo selection
That sounds like Dave that selected that turbo. Good choice and should spool like lightning.
Hopefully you get one of the good ones. Apparently they are having issues with the wastegate seating in the ss housings allowing constant boost leak. My dad has an htt ss and with the wastegate disabled it is still only making 40psi.
Andy
