htt 62/65/12??? need help
will this 62/65/12 be a good turbo for me or no
i plan on maybe getting smarty sr.
when my trans is finished, will i be able to run the smarty or will it be to hot
i do tow but i go to the track to
thanks tommy
thanks tommy
If you stay with your current mods +the smarty you'll have a great runnin truck. Aftermarket stix will get a little toasty but doable. I'd get the 13cm SS housing if you have the ability.
If you just go with a Smarty that setup will be good, but if any upgrades are in line might wanna go with a 14cm housing or a 62/71 exhaust turbine
Brett
Brett
I'm curious if anyone is running this turbo at elevation? I live at 5000 ft and drive between 5000 and 7500.
How does spool up compare to stock?
I'm not sure if there is a good single turbo for elevation? Ball bearing Garrett?
Are twins the only way to go?
CoolumConst
23
07-16-2008 05:16 AM
O.T
16
01-14-2008 02:47 PM
bridleman
07-09-2007 09:37 AM
CTD03
13
07-09-2007 04:32 AM
Bobcat698
11-08-2006 11:20 AM
