Hp!! What do you guys think??
All right with my 05 in my sig with current set up.
Edge juice with attitude
Edge ez
Air dog
SPS 66 14
flux 2's
Arp studs
Don M Valve springs
schied Cam
What kind of horspower toque numbers do you think I would put down? Also what would be the difference if I turned the edge off and run the Bullydog with Crazy Larry and Ez? Also what kind of RPM's do you think I can saftley turn?
Edge ez
Air dog
SPS 66 14
flux 2's
Arp studs
Don M Valve springs
schied Cam
Well you certainly have the physical mods for 600+hp, but I doubt you'll get there with the Juice/Attitude. Just don't see many high hp trucks using Juice/Attitude, even HOT Juice on my hit a limit pretty quick.
I would just use CL with EZ, or add TST and Smarty.
Well the juice is just what I use for when I am daily driving to help spool that big turbo. When the pulling season starts that gets turned off and the bullydog gets turned on. I think the bullydog with crazy larry stacked with the ez I will be in the 600hp range. But for daily driving the crazy larry is a liitle much.
I agree that the CL and EZ should put you in the 600hp range, but I would still use the BDTD w/Low End Option on performance and the EZ for daily driving. I ran a HOT Juice/EZ/BDTD w/CL for a short while. They did not make a good triple stack on mine. As long as you can spool the turbo with the Juice/EZ then sounds ok with me. But I would still try a Smarty/EZ combo to get a comparison. The BDTD w/CL/TST/EZ was very good stack on mine, but the Smarty in place of the BDTD was even better. Just my experiences.
I leave the bullydog off almost all the time unless I am pulling that is the only time it comes on. I do not triple stack expecially with those to it has way to much timing with juice and BD stack gives a bad rattle. I've had friends with some bad experience with the smarty and not very good custumer support so I am not going there right now not bashing or anything but a few people with some bad experiences I might try it later but for right now I am very happy with the bully dog. This is not a dedicated pulling truck just a weekend warrior in the summer and a daily driver but I want to win some local pulls not just attend. 600hp is plenty for me expecially around here I will be good competion.
Kman9090,
Understand, but I would keep an open mind for down the road. With your physical mods you can do a lot of different mods and stacks for both street and track.
So for pulling you think a smarty and ez would be the best combo? I haven't really look into a smarty much but what kinda of hp do they push out? I know they have a setting you can turn 4000 rpm with don't they. I just want the right modds to put down good hp numbers but still keep the truck very reliable. Thats why I leave the juice on for street use because it is safe and I really don't need another blown motor. So anybody got any other oponions on the route I should go? Or do you think I have a good setup with the crazzy larry and ez combo? Any help would be appreciated. What kinda of Horsepower are you putting down ramswheelby4? Do you run all 3 chips or do you turn one of them off. But I do not want to be stacking 3 chips. So if I buy another chip which way do you think I should go smarty or TST? All I want is about 600-700 hp any where in there is acceptable but don't want to go much higher then that.
Also how do I adjust this turbo to get more boost? Right now it's wastegated at 40pounds and want to build more I was thinking 50pounds should be safe?
Hot Juice
Mp-8
Flux 1.8s
A3k turbo
Got me 558/1240
I don't think the ez is quite as good as the mp-8, but you have a bigger turbo and a cam and slightly bigger injectors. I would think you should hit 600hp just about right on.
Mp-8
Flux 1.8s
A3k turbo
Got me 558/1240
Yes for now a modified one will come this spring when the pulling season starts. All right I think I'll be plenty happy with this setup and when I get a modified pump I will throw the bullydog on there.
