How you guys liking your DIablo Predators?
#31
I guess I will throw my experience in here.... 1st off I am not bashing Diablo or doubting it works great on your truck, I am a firm believer of "some trucks like certain tunes, some dont"... with that said........
I stacked the diablo with my EZ on the "stacker" extreme tune, and was very disapointed.... Under NORMAL acceleration it would not even slip my stock clutch? Maybe its becuase it was a EZ and not a Puck? But after I installed the tune my truck ideled at 900rpm(100 over stock)..... and was all of a sudden hard to start These problem still remained after I tuned it back to stock.... hard to start, and ideling high....
Anyone else have problems like these while/after the download like this??
I borrowed a Smarty and programed it, and turned back to stock for the stock tune from Smarty, and now everything is good.
#33
Armstrong, it is true that some of these trucks just don't like some boxes. I have had several boxes on my truck and almost all of them have had at least one issue that I didn't like (CELs, hard starting, performance problems). I haven't seen anyone else with your particular problem. All I know is that this programmer on the Extreme RKL tune is awesome from the bottom end to the top end. The only thing I don't care for so much is that if i lug the engine at all it smokes like a freight train... No big problem though. Heck, I've even had a couple issues with this Predator but I like the thing so much I'm just dealing with them in the hopes that they will figure the problems out for me.....
#36
Bodie did you upload just the stock tune back into the truck or the original backup you need to go to the tune selection screen and scrool down to original backup and download it that it trucks stock factory tune this should take care of your problems. My truck after the trial tune wore off kept surging and idleling rough and we uploaded the original backup and that fixed the problems. You need to try the puffer or a custom tune also i bet that clutch wont hold for long too bad the u7130 doesnt have rkl like our u7131 does but yall get custom tuning.
#39
Correct. With added fueling your truck is capable of making more than stock boost but the computer will defuel once you reach 31psi or somewhere close to that. More boost equals more power and lower egts. The boost fooler makes your truck's computer think you are still below the 31 psi and allows for more boost without throwing overboost codes. The stock turbo is really only good for around 40psi and at that point or higher the turbo will start to destruct.
#43
#44
That's if you are lucky enough to have the right year truck!! Mine gives me the added power and I can clear codes. That's it!! I think the newest version gives me the tire size change option but I'm not sure.....
#45
On my 05' the difference between say regular Extreme and ExtremeRKL is like night and day. RKL is truly amazing. And you do not need the Puck, EZ or any other added pressure box when running RKL. I'm confident that with Diablo RKL and VA on 70hp that I'm way over the 600rwhp mark... Will confirm in the near future.
