How to remove Chrome Rocker Paneling
Im wanting to remove the chrome rocker paneling thats on my truck. Does anyone know an easy way to do so. Im familiar with the fishing string method, would that work on rocker paneling too. Any help is much appriciated thank Joel.
Someone told me that a big up to date body shop has a tool that heats the glue without heating the surface and it comes right off. Might want to call a couple shops and ask.
Shane
Same here Forrest. It was there when I got the truck. I found some cool black xmc diesel wheels so now i have to get rid of all the chome stuff.
I removed it off of my x's van one time, a heat gun, some plyers, and alot of muscle. After you get the chrome off, then you need a big eraser wheel. there was a post somewheres (I think it was in non drivetrain 3rd gen) that says where to get this wheel. If you use a petroleum based remover it will cloud the paint. But with the wheel your paint will be like new. Oh and one other thing, you need to have a high rpm tool to turn it, like a pnuematic drill,, it has to be faster than a regular drill
Kevin
Kevin
I need to do the same thing to my truck. I put a dent in my cab corner the other day and now the back door, front of box, and cab corner stainless is junk. Instead of replacing it I would like to clean up the truck by taking all the stainless off. The only thing I'm worried about is the paint not matching behind the stainless beacause it never faided like the rest of the truck. Did anyone have that problem??? If I may ask did any of the body shops quote you a price on taking it off?
Kevin
Kevin
and, unfortunately, the adhesive will stain the paint over time... I didn't use any "remover" on mine other than a pair of pliers to pull the stainless (well, and a chisel to lip the stainless up to grab it w/ the pliers) and an eraser wheel to remove the adhesive and backing. it was some WORK!!! no remover and it still stained the paint
How long was the stainless on your truck? Im trying to figure out roughly how long the stainless has to be on a truck before it affects the paint. I suppose it all depends on if it was parked outside or in a garage, and how strong the sun is in your part of the country. How noticable is the paint affected?
CumminsRedneck
05-14-2007 11:43 PM
smknram
03-03-2007 03:35 PM
nfsommer
21
10-09-2006 09:32 PM
