How much power can the stock tranny hold? (06 auto 4x4)
Old 12-14-2008, 03:36 PM
TN_diesel's Avatar
Ok so Im about to reprogram my 06 cummins and i obviously want the most power i can get, but i dont want to have to rebuild my tranny and upgrade my turbo and stuff. I really like the edge juice with attitude as its adjustable on the fly, shows all the stats of the engine, and has a built in turbo timer. I've heard that any more than 100hp added and ill need to upgrade my tranny. I will be taking this truck to the strip occasionally just for fun with the guys. So any recommendations or suggestions? Thank you.
Old 12-14-2008, 03:42 PM
snoyes's Avatar
Some guys have had their transmissions hold up over 100 HP, most have eventually started to slip them (and once slipping their demise seems to accelerate very quickly). The Edge will most likely put you over the 100 HP level, and with you wanting to take the truck to the strip, you're a definate candidate for a modded trans....
Old 12-14-2008, 03:45 PM
TN_diesel's Avatar
what kind of mods are we talking about exactly? im a broke high school kid who dumps all his money in this truck lol which isnt much
Old 12-14-2008, 04:04 PM
raychem's Avatar
Keep the tranny serviced and maintained; 70 HP max for longevity. The REALITY is that no one can tell you how long or how much HP it will hold. I would advise you to get an upgraded VB which will help your tranny quite a bit. If your gonna head to the track and strip your truck and/or you drive it hard with the extra power....then you will be on borrowed time with your tranny.
Richard
Old 12-14-2008, 04:29 PM
TN_diesel's Avatar
what exactly is the vb? (diesel noob)
Old 12-14-2008, 04:43 PM
Mr Bee's Avatar
VB= Valve body.
TN Diesel... From personal experience I have driven 100,000 miles with a stock trans and a smarty on 90HP. That said, I do not dirve like an idiot and race away from every stoplight. If your truck is going to see track duty, be very careful as the will increase your chances of failure many times. They do not like boosted launches in stock form, resist from doing that. There are some who do this but there are many many more who have tried and failed with costly repair.
There is not really a non-costly way to get an upgrade for your transmission.
Valve body and torque convertor will run you about 1500-1700 and then labor if you cannot do it yourself. I assure you that if you look at the stock flex plate and a billet one you will break your arm getting the money out of your pocket. (Another 400.00) The stock one is so flimsey. If you are serious about keeping your truck, there are many quality transmisson builders, and IMHO just bite the bullet and do it right and forget it. I have had my Gorend
transmission for 25,000 miles and LOVE IT!! It changes the truck completely and I never worry about painting a little pavement every so often, I know my trans will hold. There is a lot of peace of mind with the purchase.
Old 12-14-2008, 04:49 PM
TN_diesel's Avatar
how much did it run you?
Old 12-14-2008, 04:50 PM
mulisha's Avatar
cant have both, if your gonna go to the track, a tranny is in order.70hp max with a stock tranny.
Old 12-14-2008, 04:59 PM
TN_diesel's Avatar
so what recommendations would you make then? ill only being going to the track maybe 4 times in a year at about 15 passes each time, should i do a built tranny or just do a torque converter and vb?
Old 12-15-2008, 02:28 AM
TexasCTD's Avatar
Cheap, Fast, Reliable!! Pick any two.
Old 12-15-2008, 08:01 AM
MDW
MDW's Avatar
This question has been asked a million times.
The honest answer is NONE.
The stock trans. can't hold stock power if you drive it hard.
Before you beat the truck make sure you have the trans. rebuild money in the bank, otherwise you are going to be out of the truck for a while.
Just my .02
Michael
Old 12-15-2008, 08:08 AM
cbrahs's Avatar
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
I am laying down 445 hp 1036 tq on 37" tires and can slip the converter at will. now with the 39.5" tires, i am treading on thin ice.
Old 12-15-2008, 08:12 AM
Sam Turner2's Avatar
Guys, I'm kinda in the same situation, is there a price diffrence in a built tranny if I blow mine before I buy a built one? as in will I loose my core charge? Also whats the price range for a built trans?
Mine was acting bad untill I changed 7 quarts of oil and the filter, now it acts like new for the last 2K miles. I added 2 quarts of Lucas stop slip also.
Old 12-15-2008, 10:54 PM
phantom 309's Avatar
so if you were going to do everything right on a built tranny about what would it run price wise?
Old 12-15-2008, 11:24 PM
annabelle's Avatar
$6000.00 or so.
Quick Reply: How much power can the stock tranny hold? (06 auto 4x4)
