how much nitrous can a modded cummins 2003 handle
Old 11-05-2005 | 03:55 AM
fredw's Avatar
now before we get into this, i am finding some info out for a buddy that is not handy with the keyboard
he has an 03 dodge, with 130over injectors, fuel mod done from the tank to the CP3(will sustain 9lbs on Wot), a special NADP 61m turbo(will spike47psi), afe intake and 4" exhaust, powershot 2000 propane system, he runs the predator130, nadp 120 and some other tunes (not sure), no head studs or oring head
he runs a best of 12.6 at the track, with a 8 second 1/8 mile, but then feels defuel to the finish, running the 315 pro comp tires
he seams to have a slight smoke Haze down the track
we will be dynoing soon and now being new to nitrous he is not to sure what jet sises he will need, his setup consists of a single stage -6an line from the bottle to the solenoid
thanks for any info with this
as for my duramax we would start with a .030 and work up till the smoke clears, is this the same for the cummins or can someone save us some time
Old 11-05-2005 | 06:41 AM
king d's Avatar
fred he may be running out of rev limit,does he have a rad ?as far as jet sizes they are gonna be similar to the the dmax,however it is always the safest to start small and grow.i run an 88 in my 05 ctd
Old 11-05-2005 | 11:59 AM
fredw's Avatar
JESS: he does have the rev problem, but was hopping the dealer was gonna get rid of that if they could, just mentioned that the other day
as for the rad(i am not sure what you are asking)?
then for jet sises, we will start low and work up, Jess the boys from bully-dog are sending us a special box that they say will be a contender, have you tried theirs out? or any other ideas for big numbers
have you used WI on your cummins yet, can WI and nitrous be used together, i know it cannot with the max?
thanks agin for the help JESS
Old 11-05-2005 | 03:37 PM
John Rodriguez's Avatar
Tire Hater
I too run an .088 jet
Old 11-05-2005 | 04:08 PM
blowin smoke 03's Avatar
Nitrous
I have run a 100 jet in mine for about 6 months,but not sure how much it actually flows causes it's on a small feed,with a#4 line and and a small solenoid!!!
Old 11-05-2005 | 04:57 PM
Ult680's Avatar
I ran a 160 shot but found the lines and solenoid to be the limiting factor. This was on the nitrous kit out of Summit. Never had any problems.
Jeff
Old 11-05-2005 | 07:18 PM
fredw's Avatar
where is the best spot to inject the nitrous at, this kit he received , is designed to have a minimum restriction of .125 on the nozzel
what about waterinjection, and nitrous, thanks again
Old 11-06-2005 | 12:52 PM
banshee's Avatar
I run about 58 lbs of boost with my twins, and I'm now running .066 worth of N20. I have studs, and so far it hasn't lifted the head off. As long as your bring it in smoothly it shouldn't be too hard on the motor. FWIW I gain about 80 hp running this jetting.
Old 11-06-2005 | 02:48 PM
fredw's Avatar
thks, i will tell him, what hp are you running like that, must be real strong
Old 11-06-2005 | 03:09 PM
BigBlue's Avatar
592 rwhp #2, 677 rwhp w/ N20
13.23 @ 104, 1.85 sixty
Old 11-06-2005 | 05:26 PM
banshee's Avatar
thanks Big Blue!
Old 11-06-2005 | 06:36 PM
BigBlue's Avatar
No problem.
Mike D
87
04-10-2008 04:18 PM
GO 4LO
16
09-20-2004 02:32 PM
shaft
09-09-2004 05:23 AM
AK RAM
01-15-2004 05:48 AM
finallydiesel
01-06-2004 05:39 PM
