How much FP is too much for a CP3?
How much pressure is too much for a CP3? I know excessive FP would harm a VP. Is too much FP (say over 22-23 psi) harmful to a CP3? My Walbro (392) runs as high as 23 psi at times, so I'm worried it might be too much. Thanks!
Cool, so as long as I stay under 1 mil psi, I'm good? That's what I figured, because I'd never heard bad things about excessive press with CP3's, but I thought I'd ask anyway.. Thanks for the reply Rusty!
the one thing to consider is if you are still using the factory fuel filter set-up, your plastic cap will be a limiting factor. genos offers the billet lid, but even it has its limits. if you want to crank up the fp, you should go w/ an aftermarket filtration system like a one from gdp or fass
brett
brett
jjrightmire1973
11-20-2008 08:20 AM
PourinDiesel
15
06-16-2008 09:51 AM
BADBOWTIE
28
07-14-2007 02:36 PM
megacabrule
33
05-10-2007 01:07 PM
