How much fluid to change valve body/DD pan
I'm getting ready to do my HTS valve body. How many quart's of trani fluid will I need with the Mag-Hytec pan. Any other tip's before I start. Thank's
I would go out and get some large measuring cups or use 1 gallon oil jugs to gauge the amount of fluid you get out that way you know exactly what to put back in.
You wont have to worry about being over filled or under filled.
Location: misplaced Idahoan stuck in Albuquerque, Roughneckin on RIG 270
the dealership did the 1-2-1-2-1-2 shift problem on mine along with a filter and i watched him add the fluid. I have the stock pan and it took 6 quarts to top it off (to give you a rough idea)
tndiesel
07-15-2011 11:36 AM
barryp
10-25-2007 06:07 PM
Pooter
10-04-2006 12:26 PM
Pooter
08-03-2006 05:07 PM
RobG
08-18-2005 01:22 PM
